M1Gunner
Gainesville, Fl
00'BlueSteel
Carolina
Man that thing is a beast! What setup you runnin lift&tires?
375/65r16s
16x10s
1.25” front spacers
2” rear spacers
You helped me decide to go that way, we talked about your setup and the whole tire poke thing, running 15 wides on 9” runs. I still want the old school 18x12s w/ 33x15.50s. Closest I’ve found is custom 16x16 wheels and swamped 35/16r16s
eand28
Pennsylvania
375/65r16s
16x10s
1.25” front spacers
2” rear spacers
Check out TJ Forged. Bringing back the old school sizes. Started by Taylor Weld who used to be the president of Weld Racing like 12 years ago
TheAutumnWind
Crap i have to do my oil cooler lines now. They are definitely weeping and seem to be leaking @ the connection to the block. Any tips?
I've been noticing a a leak so I bypassed the rad for the transmission lines (got rid of the leaking fittings and crimps) and found out my oil cooler lines and transmission pan gasket are also leaking. Not very happy.
*Well shit. Not a fan of the bypass. Temps are higher even with ambients in the 65* range it just takes much longer to get it up to temp. * My trans cooler is much bigger and thicker than stock too...
I know the pt.net guys run big stalls with a trukool 40k so i figured id be ok. Damnit. Ill have to undelete the rad soon.
Edit: might be ok actually. Turned out it was leaking once it got up to temp bc i had a clamp that was not tight enough.
375/65r16s
16x10s
1.25” front spacers
2” rear spacers
Wow, 16x16's!
TheAutumnWind
00'BlueSteel
Carolina
Nice, I’ll have to look them up.
First pic, that blue looks amazing!
That’s how it looks in the sun, I need to get more pics like that.
That is a lot of tire! What tie rods/steering setup you running?
I’ve got the Cognito idler pivot assembly upgrade, Cognito heim joint tie-rods, RedHead HD Steering box, and I put new AC Delco pitman and idler arms on when we did the lift.
I don’t have a good photo of the idler assembly and center or the gear box, O have to grab some tomorrow and put them in my build thread, here you can see tie-rods.
HiHoeSilver
Away!
Chicago
Needs moar rust...
:challenge:
Rome58
