Isaiah W
Just got my Tahoe back from the mechanic's today. Had the water pump and temperature sensor replaced, replaced a front wheel bearing (triggered ABS light) and had brake pads and rotors done on all 4 corners. Mechanic also checked all belts and hoses, bearings, bushings, ball joints, steering components, control arms. Ended up being about $1400.
Sam Harris
Texas
I wanted to program the Homelink transmitter to open my garage door, and found out the Yukon's version is too old to work with my door opener, circa 2015. After ordering the $40 "compatibility bridge" I decided that was a waste, and I wasn't going to pay for that, and cancelled the order. I copied another user's method found here, and added a momentary switch to the overhead console, somewhat hidden, to get the job done. This works great! The opener already had a pretty damn good range (over 1 block), but now it's probably a couple thousand feet! I haven't tested how far yet, but to give you an idea: View media item 27535 Not that I really want to open the door until I'm much closer, but wth.. that's a hellova range! IMG_3793.jpg IMG_3794.jpg IMG_3795.jpg IMG_3796.jpg
Not sure why my first image didn’t come through.. d837ffa0c189ceab85303ac41a15ba91.jpg
treehan77
TYF Fiend
Crestview, FL
I wanted to program the Homelink transmitter to open my garage door, and found out the Yukon's version is too old to work with my door opener, circa 2015. After ordering the $40 "compatibility bridge" I decided that was a waste, and I wasn't going to pay for that, and cancelled the order. I copied another user's method found here, and added a momentary switch to the overhead console, somewhat hidden, to get the job done. This works great! The opener already had a pretty damn good range (over 1 block), but now it's probably a couple thousand feet! I haven't tested how far yet, but to give you an idea: View media item 27535 Not that I really want to open the door until I'm much closer, but wth.. that's a hellova range! View attachment 213746 View attachment 213747 View attachment 213748 View attachment 213749
So you added a button instead of clipping the remote to the visor? Why?
Fless
Super Moderator
Elev 5,280
Could you possibly do a write up as well as posting links to the info that you used?
From the owner's manual, Homelink instructions attached. Or, if you prefer, in text:
HomeLink® Transmitter
HomeLink® a combined universal transmitter and
receiver, provides a way to replace up to three
hand-held transmitters used to activate devices such as
gate operators, garage door openers, entry door
locks, security systems and home lighting. Additional
HomeLink® information can be found on the internet at
www.homelink.com or by calling 1-800-355-3515.
This device complies with Part 15 of the FCC Rules.
Operation is subject to the following two conditions: (1)
this device may not cause harmful interference, and
(2) this device must accept any interference received,
including interference that may cause undesired
operation.
This device complies with RSS-210 of Industry Canada.
(1) this device may not cause interference, and
(2) this device must accept any interference, including
interference that may cause undesired operation of
the device.
Changes and modifications to this system by other than
an authorized service facility could void authorization
to use this equipment.
Programming the HomeLink®
Transmitter
Do not use the HomeLink® Transmitter with any garage
door opener that does not have the “stop and reverse”
feature. This includes any garage door opener model
manufactured before April 1, 1982. If you have a newer
garage door opener with rolling codes, please be
sure to follow steps 6 through 8 to complete the
programming of your HomeLink® Transmitter.
Read the instructions completely before attempting to
program the HomeLink® Transmitter. Because of
the steps involved, it may be helpful to have another
person available to assist you in programming the
transmitter.
2-53
Keep the original transmitter for use in other vehicles as
well as for future HomeLink® programming. It is also
recommended that upon the sale of the vehicle, the
programmed HomeLink® buttons should be erased for
security purposes. Refer to “Erasing HomeLink® Buttons”
or, for assistance, contact HomeLink® on the internet at:
Be sure that people and objects are clear of the garage
door or gate operator you are programming. When
programming a garage door, it is advised to park outside
of the garage.
It is recommended that a new battery be installed in
your hand-held transmitter for quicker and more
accurate transmission of the radio frequency.
Your vehicle’s engine should be turned off while
programming the transmitter. Follow these steps to
program up to three channels:
1. Press and hold down the two outside buttons,
releasing only when the indicator light begins to
flash, after 20 seconds. Do not hold down the
buttons for longer than 30 seconds and do not
repeat this step to program a second and/or third
transmitter to the remaining two HomeLink® buttons.
2. Position the end of your hand-held transmitter about
1 to 3 inches (3 to 8 cm) away from the HomeLink®
buttons while keeping the indicator light in view.
3. Simultaneously press and hold both the desired
button on HomeLink® and the hand-held transmitter
button. Do not release the buttons until Step 4
has been completed.
Some entry gates and garage door openers may
require you to substitute Step 3 with the procedure
noted in “Gate Operator and Canadian
Programming” later in this section.
4. The indicator light will flash slowly at first and then
rapidly after HomeLink® successfully receives the
frequency signal from the hand-held transmitter.
Release both buttons.
5. Press and hold the newly-trained HomeLink® button
and observe the indicator light.
If the indicator light stays on constantly,
programming is complete and your device should
activate when the HomeLink® button is pressed and
released.
To program the remaining two HomeLink® buttons,
begin with Step 2 under “Programming HomeLink®.”
Do not repeat Step 1 as this will erase all of the
programmed channels.
If the indicator light blinks rapidly for two seconds
and then turns to a constant light, continue with
Steps 6 through 8 following to complete the
programming of a rolling-code equipped device
(most commonly, a garage door opener).
2-54
6. Locate in the garage, the garage door opener
receiver (motor-head unit). Locate the “Learn”
or “Smart” button. This can usually be found where
the hanging antenna wire is attached to the
motor-head unit.
7. Firmly press and release the “Learn” or “Smart”
button. The name and color of the button may
vary by manufacturer.
You will have 30 seconds to start Step 8.
8. Return to the vehicle. Firmly press and hold the
programmed HomeLink® button for two seconds,
then release. Repeat the press/hold/release
sequence a second time, and depending on the
brand of the garage door opener (or other rolling
code device), repeat this sequence a third time
to complete the programming.
HomeLink® should now activate your rolling-code
equipped device.
begin with Step 2 of “Programming HomeLink®.”
Do not repeat Step 1.
Programming
Canadian radio-frequency laws require transmitter
signals to “time out” or quit after several seconds of
transmission. This may not be long enough for
HomeLink® to pick up the signal during programming.
Similarly, some U.S. gate operators are manufactured to
“time out” in the same manner.
If you live in Canada, or you are having difficulty
programming a gate operator by using the
“Programming HomeLink®” procedures (regardless of
where you live), replace Step 3 under “Programming
HomeLink®” with the following:
Continue to press and hold the HomeLink® button while
you press and release every two seconds (cycle)
your hand-held transmitter until the frequency signal has
been successfully accepted by HomeLink®. The
indicator light will flash slowly at first and then rapidly.
Proceed with Step 4 under “Programming HomeLink®”
to complete.
2-55
Using HomeLink®
Press and hold the appropriate HomeLink® button for at
least half of a second. The indicator light will come
on while the signal is being transmitted.
To erase programming from the three buttons do the
following:
1. Press and hold down the two outside buttons until
the indicator light begins to flash, after 20 seconds.
2. Release both buttons. Do not hold for longer than
30 seconds.
HomeLink® is now in the train (learning) mode and can
be programmed at any time beginning with Step 2
Individual buttons can not be erased, but they can be
reprogrammed. See “Reprogramming a Single
HomeLink® Button” next.
Reprogramming a Single HomeLink®
Button
To program a device to HomeLink® using a HomeLink®
button previously trained, follow these steps:
1. Press and hold the desired HomeLink® button.
Do not release the button.
2. The indicator light will begin to flash after
20 seconds. While still holding the HomeLink®
button, proceed with Step 2 under “Programming
HomeLink®.”
Resetting Defaults
To reset HomeLink® to default settings do the following:
1. Hold down the two outside buttons for about
20 seconds until the indicator light begins to flash.
2. Continue to hold both buttons until the HomeLink®
indicator light turns off.
3. Release both buttons.
For questions or comments, contact HomeLink® at
1-800-355-3515, or on the internet at
www.homelink.com.
2-56
  • Homelink.pdf
Sam Harris
Texas
Pilot
Bloomfield, NJ * Lewes Beach, DE * Buenos Aires
As far as a write up for the mod I did, it just depends on your opener, where you solder your momentary switch leads. Pretty easy to tell once you open up the remote, look at the button you have programmed for your opener, and wire in the switch. I used this switch: https://www.amazon.com/gp/aw/d/B000BW0YWG?psc=1&ref=yo_pop_mb_pd_title
THE Sam Harris??
Nice mod. I've been wanting to rig the second garage door button in my Tahoe to open the security gate in my neighborhood. Right now we have HOA issued fobs. I'm sure it's possible but I wonder how difficult?
Sam Harris
Texas
THE Sam Harris??
It’s likely very simple. I was actually hoping to wire to the installed HomeLink button, but it’s soldered to a ribbon cable, with the other 2 buttons. There are 5 leads on each of them. I tried to get the needed leads, to activate the switch, but no matter which I used, the switch would activate without pressure. I opened up this tiny switch, so I could look inside, and determine the needed leads, but it pretty much fell apart in my hands, so I decided to continue with the additional momentary button.
mohammadalhashim1
