Sam Harris
Texas
I just ordered retrofit brackets, Morimoto mini H1 projectors, Hylux 45 watt ballasts, Morimoto 5500k bulbs and bulb holders so I can do a true retrofit in my new Anzo u-bar headlights.
You doing a mini-thread for this..? [emoji6] setup looks badass now. After the retrofit, it will work just as well as it looks. [emoji106][emoji631]
Sam Harris
Texas
That's a great idea, Also so some cushioning for the lights when hitting bumps the lamps aren't bouncing around.
My crappy OEM style NBS replacements came with a rubber gasket that goes around them and actually helps with that. But the weatherstrip looks much cleaner, and is also a tighter seal. Great idea @Rocketman !
05Single
afraid of the dark
Center surround painted
I never knew this was a 3 piece grille.
I am in the process of headlight/ corner light upgrades on The Beast. New Anzo u-bars which have clear lenses so I bought some corner lights with flat black housings and clear lenses to match. Undecided on whether I will bake anything open or not. Might open the headlights and remove the reflectors/ paint the chrome part, or open them all up and PTM in Pewter. Also undecided on doing a retrofit on the headlights. I checked with a maker of the Denali retrofit brackets and he said they will work on these Anzo's so if I do that it will be easy. I need to check nighttime light output to see if it's even neededView attachment 226654 .
So you lied to us , you are baking these bad boys open !!!
replacements ?
briwesric
