mikeyss
Longmont, Colorado.
That repair is spot on, they look great. I use Dawn diluted in a spray bottle and spray light on the seat but more on a micro fiber cloth and gently scrub. It pulls dirt out. But you must apply leather conditioner on it after you clean them.
Alrighty then:
Unfortunately I now have a new project: cleaning the original leather on my seats...:doh2:
Scrubbing bubbles, then leather conditioner. You won't regret it. Seats came out great.
Scrubbing Bubbles for sure. It works great as a one-time cleaner, just don’t use it on a regular basis. Use a small bristle brush with it and lots of clean rags. You’ll be amazed.
Trying to find a coolant leak on the ol lady's 04 suburban, I pumped it up to 15 twice already and it's loosing pressure over a few minutes but can't find the dam leak, checked every suspect place, no drips on the ground everything is dry, sprayed the reservoir with soap&water no bubbles wtf? Already did a block test it passed
3Dog
Rocky Mountain high...
Thanks for the cleaning ideas, I will give it a try. :beer:
Water pump I guess? Can't find anything anywhere else, it's loosing about 1/2 gallon a month slow leak the bottom of the pump has a couple drops dangling and discoloration, also found one of the heater hose lines that was previously fixed with a clamp was dripping, so tightened that up and see what it does, not sure if a couple drops under the water pump is normal or not
BADRIDES
Been using that for years
SinStar999
