so washer tank still leaks. gonna replace the other pump. if one was blown up, maybe this one has a crack i cant see.
in other news. i dropped a large deposit on the pro charger install for the SS. should be dropping it off in a few weeks.
usually leaks are from either a cracked pump or bad grommet, you might be replacing the tank and have it not be the problem
tank looks ok. thanks for reminding me tho. i forgot to order the pump. work is getting crazy, a man short and its hot as hell out.
mostly those pumps crack and leak just happens from age sometimes you have grab a few from the junk yard to find one that's not cracked you can swap them out from the bottom if you unbolt the tank it gives you just enough room to do it.
DenaliReyes
Detroit, MI
20200611_082755.jpg Ups arrived late, managed to wire the bumper lights, tomorrow will finish it off. Did not get a chance to plug the LED halos. Mosquitos hungryAF lol
Resistors or flash module?
What do you suggest?
If I get the flash module then I dont need resistor on every line i want LED on?
Switchbacks are on the parking/signal light.
I want to add the halos to the turning signal. So the blink when I turn but stay on when I drive.
Sam Harris
Texas
View attachment 249730 View attachment 249732
You want the halos to blink with the turn signals, which are also switchbacks?
No offense intended, but I really think the halos should either be on or off..
DenaliReyes
Detroit, MI
Non-taken.
I see a video of the newer headlights with the led C-bars that flash like that. I kind of dig it.
I havent seen halos do that. So will have yo try.
hwampler
