I know, I know. I’ve seen somewhere online that the oem drive cycle only takes about 15 minutes versus the hour or so it’ll take to go 100 mi.
It's not just mileage. There are a handful of events (key on/off cycles, gear changes, etc.) that have to happen to complete the various monitors.
Case in point: Girlfriend had an '02 Montero Sport with a persistent CEL so it wouldn't pass inspection. I replaced a few cheap possibilities, cleared the codes, then ran it on jackstands with a stick on the pedal to hold the speed around 70MPH while I did other things. After about 75 miles, the light still hadn't come on. I set it on the ground to take it around the block to ensure. Just as I had made the turn to come back home, that damned CEL came back on for the same code.
dwinters14
Replaced oil pan gasket, upper and lower ball joints, front shocks, torsion keys, rear springs and I attempted to replace my rear shocks but the rough country kit I got didn't work! The aluminum insert didn't fit into the bushings.
Also I still see oil leaking, but it's coming from somewhere where the oil pan touches the transmission. Any ideas? It's no visible so I'm gonna assume it's not the oil pan gasket.
Rear main?
Ftrsavage
Pittsburgh Pa
Sam Harris
Texas
All that work, and no pics?!?
Smityinms
