Bear77
South FL
You might be able to loosen the hood hinge and move it a smidge, worse case scenario remove the hinges and notch them, doesn't take much on one end to make a difference on the other end.
I was trying this too! Not sure if I’m thinking correct when you said to notch the hinges? Did you mean to open the holes a little more?
You can loosen the bolts that hold the hinges to the hood and adjust it that way too. Looks like it needs to move to the driver side a bit. It takes patience and some fuckery. You have to open it, loosen the bolts on both sides, move one to the side and tighten, close it slowly to see if the other side needs to go fore or aft, tighten that side, close it slowly, etc. Pretty much need a helper and mark the locations of the bolts by drawing a circle around the heads/ washers so you have a reference of where you started from. I did mine by myself and got kind of good at it after 2-3 times.
Yes it does need to move over a bit towards drivers side as that is where it has a big gap compared to passenger side. I’ll take more pics in the early daytime to get a better view of it.
If it won’t go over you can use a die grinder to widen the slots in the hood by a bit so it will.
Bear77
South FL
Thought he already did that. Unless I’m mistaking him for someone else?
pickegs
