I never see anything with an LS come through the shop needing a starter and the only one I killed had 300k on it. The starter part was fine it was in the solenoid cause it would just click sometimes
I’m only at 170k on my 02 so I guess I won’t worry about it. :)
Just changed mine on my 05 Express, only has 149,000 on it. Fried it! I could smell it when it went.
David Staines
Columbia City, OR
I dropped in a Sony XAV-AX5000 radio. I had one in my previous Tahoe and really liked it. The second time you do it is WAY easier... especially when you have a heat gun and solder/shrink wrap for the cable adapter. I had the whole thing done in less than an hour. I also found the correct bow-tie for my HD grille. Lastly... I finally had the AC system completely re-done.
Front end looks good.
druiddonn
Which wires did you tap into?
I tapped into the fuse box between the brake pedal and emergency brake I can't find the photo of it right now but I simply used a spade and slid it into the connection next to the existing connection I think it was an orange wire and then I grounded it to the bar that's part of the crash that come under the dash
CaliCrusin
