I’m nervous. But just how nervous should I be about this oil cap looking like this. 5cf365ff429f87925013f9b42df195be.jpg
That more solidified gunk on the O-ring tells me it may be more than just common condensation. Do you do a lot of short trips?
It’s easy enough to pull a rocker cover and have a look. That will be way more telling.
:signs75:
Pop off a cover and get some answers before serious damage occurs.
mattbta
Frisco, TX
Tying to install footwell lights. Want to use a pin on the back of the MBEC as demonstrated on another site, but I can't figure out how to get the TPA (terminal position assurance) out so I can slide my metri-pack pin into it. Argh. Made a thread in our electronics section: https://www.tahoeyukonforum.com/threads/mbec-help-back-plug.124715/
Reached out to the OP on the other site, but he hasn't been "seen" since 2019. Long shot there.
Sam Harris
Texas
I did this a couple years ago. I’ll see if I can find my post...
Ok, found my post, but I didn’t say what wire I used. Lol. It was the grey with black stripe that I tapped into.
ETA: I guess you’re asking how to get the pin out, not which wire to tap into. I’m not sure if I pulled that one out, or just tapped it another way. [emoji2369]
mattbta
Frisco, TX
As a last fitch, I know I can tap a wire. I'm trying to avoid that by using a pin into the back of the MBEC as referenced here: https://www.gmfullsize.com/threads/installing-footwell-lights-in-03.104799/post-5720705 Just no clue how to get the darn blue "TPA" out to allow the pin to insert. Teehee. It's supposed to go in the second from bottom 10th spot over.
Never pulled one from there but others I’ve pulled have a tang that needs to be depressed, just like pulling a pin out. Maybe look at the pin you’re inserting, see where the tang is, and slide a pin removal tool or tiny flat tool into the same place along the TPA.
Rome58
