mattbta
Frisco, TX
Thanks guys. I'm actually trying to put the pin IN, not remove it. This blue part the arrow points to prevents the pin from inserting. You can see I damaged it a little fiddling with it. When that part is removed, it allows the pin to insert. Then it slides over the top of the pin to keep it in place. It won't push left out of the way to allow the pin to go in. But I think the only way to do that is to remove the entire white plug but I have no effing clue how to do that. That screw won't come all the way out.
I understood. The Deutsch connectors I use have those. They click into place but if I grab them with a good pair of needle nose pliers and give them a good yank they pull out. I was saying those might have actual locking tangs like the pins themselves, only on the opposite side as the pin. I would try yanking good on one in au unused cavity that you’re not planning on using to see if it comes out. If not you’ll have to use a pin removal tool like I mentioned to remove the TPA or whatever its called. Maybe use better needle nose pliers.
I had to pull the battery and bring it inside. The damn thing was frozen!
I guess driving it every other day in sub-zero temperatures isn't enough to keep the electrolyte from separating.
I bought one of those battery heating pads to put in to help keep it warm.
I never knew a battery could freeze like that. Are they ruined once they freeze?
NoReverseYukon
NE Wisconsin
If they freeze solid, they can damage the plates and crack the case. Luckily, mine wasn't that bad.
When I first tested it, the meter said to replace the battery : it is a 800CCA but only registered about 125CCA. But after sitting down in the basement for a few hours, it now only says good-recharge and is reading about 615CCA. When I first shook it, it sounded like slush, and had a lot of frost/ice on the entire exterior.
I think I dodged a bullet - it was only manufactured in Dec 2019. Would have sucked to ruin such a new battery.
do you park it inside in a garage or outside?
With 3 vehicles and only a 1-stall garage, the Yukon and Dakota stay out in the driveway while the Passat gets the garage.
I was wondering and wondering if a decent sized reptile warming pad placed under the engine compartment would make enough heat to keep the battery from freezing.
deswilmington
