clandr1
Dallas/Fort Worth, Texas
Where is the flasher located?
Remove the dash trim around the gauges/HVAC/radio (the guy in the video below removes it with a screwdriver, but you can easily remove it with your bare hands), then remove two 8mm screws from below the knee panel below the steering wheel. It is below where the headlight controls are located on the left side of the steering column. Here are some links I used that should help:
https://www.gm-trucks.com/forums/topic/104429-where-is-the-turnflasher-relay-on-an-03-2500/
https://www.silveradosierra.com/hid...nbs-silverado-flasher-relay-help-t702120.html
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Hit up the junkyard this passed weekend. Scored a couple of parts, not what I was after but turned out great.
White bumper painted pad, will either put it on the 1500HD since it's white or possibly use it on the Hoe just need to get it painted.
Cadillac A/C knobs
Z71 Rear lower quarter moldings, has anyone used these on there none Z71. I know they must be used with flares which I have just need to gets those painted.
Rear hatch glass w/upper molding from an 05/06
Cadillac A/C knobs
That the hatch glass without the trim around the bottom?
Ummm, what. Lol
Like how is the layout of the heater strips.
There was 2 that I found, ill post a picture of it tomorrow. Noticed it really dirty or maybe stained idk.
The first one I bought I didn’t notice had film applied so when I pulled it off there went the heater grid. Not sure why someone tinted a super dark glass but it wrecked the heater grids. The second one the yard replaced it with had 3 small breaks in the grid lines that I repaired.
Mma-007
