blueinkd
I got my eye on the eibach kit too!! But lawd I just spent $450 on an upper intake job, knew gaskets, VC gaskets, knock sensors, cam sensor, oil pressure switch, knock sensor harness and two new kyb shocks as suggested a few pages ago. Me and a budy did job this Sunday.
Now I'm going to just go ahead and do lower ball joints, complete upper arms and pitman/idler setup.
Thats another $400 in parts alone. Cause I can't let my new tires on the Trailboss wheels get screwed up
treehan77
TYF Fiend
Crestview, FL
Could you tell if any oil was leaking from anywhere when you did this?
Teamiez
Dang:(. See I don't want to see this cause now I want to order the Moog HD pitman!! I also added upper control arms and lower ball joints. Heck I might as well
way I saw it was my truck isn’t going anywhere so I did it all at once and should be good for the rest of the life of the thing.
Teamiez
rockauto is the place where I get everything, good parts and a good price I don’t believe in autozone quality and prices unless you are in a tight bind. This Chevy got me a lot of rock auto magnets to!
blueinkd
So yes. I inspected the rear main seal via the peep hole on bell housing and cover looked clean. Rear main seal looked OK. What prompted me to do the job was the top of the bell housing was covered in oil and no way that's happening unless coming from the top. I only did the knock sensors and all those gaskets because I wasn't taking all that off and half assing the job. Valley pan gasket, grommets all got replaced. My friend and I were both shocked at how clean the engine was. No gunk or buildup on heads or area under valley pan. I've had rig for 3+ years now, so I'm not sure of previous owners maintenance.
Keviebear86
Couldn't wait and just went ahead installed the rough country bull bar. This one is much nicer than the westin. This is adjustable, and it has pretty drilled license plate mounts. I think it was a good purchase.
Now to get rid of all of the chrome...
Keviebear86
Does anyone know where I can tap into a power source for two light bars? A preexisting fused location on the fuse box under the hood? I'm trying to minimize all extra wiring necessary. These two lights will be on the same toggle switch. Any help would be great, thanks!
m86stanggt
