After having someone try to steal 3 of my four vehicles, I like the fob from Viper...
I have my viper on there as well, however when autostarting in the morning the oem fob will activate the heated seats, the viper will not, idatalink sells modules to make it work with the viper I just haven't pursued it.
Only place that I would think is the closest to you would be:
RICO AUTO COMPLEX
501 W COAL AVE.
505-722-2271
They show to have 2 of that hose in stock. Maybe they'd be willing to ship.
If not a dealer from:
Sunset Auto Center, INC.
1300 North H St.
Lompoc, Ca
805-736-7577
They show to have 1 in stock.
favor?? any way you can look up the front valance (part number) for a 2016-2018 1500 silverado z71 midnight edition (w/tow hooks) ? I am thinking about deleting the chrome mustache and that is the way, I don't have a vin for the midnight, I need the one that goes right under the bumper, not the very bottom thin piece
so far I am coming up with 84029800 but not sure if that is correct
clandr1
Dallas/Fort Worth, Texas
I last changed my transmission fluid around 200k miles, and since then I've had a recurring occasional slip from a dead stop, as well as an occasional hesitation when downshifting to pass on the highway. After doing some reading, it seems the symptoms may be traced back to my using Dexron 6, when the vehicle calls for Dexron 3. Dexron 6 is supposedly backwards compatible, but after doing some research it seems the viscosity rating is lower for Dexron 6, meaning the fluid is thinner, which can apparently mess with fluid pressure in higher mileage transmissions.
Today I changed the fluid back to Dexron 3, and will drive it for a while to see if it solves my slip/hesitation issue.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
I look into it on moday
I have never heard of that. My understanding is Dex 6 is just an improvement to Dex 3. I have also heard from my trans builder that trans fluid is trans fluid, the trans doesn’t care if it’s the cheapest or most expensive. I’m curious to see what you observe.
Sam Harris
Texas
Ah crap..! I just used Dex6 as well…
clandr1
I'd never heard of it either, but apparently there are slight differences:
Lol. I just read several threads on BITOG and the consensus as far as I read was the viscosity when cold is thinner with Dex 6 but not after it warms up, and Dex 6 has better shear properties. Several members stated they think their older transmissions shift better with Dex 6. Also to note- this post is wrong concerning compatibility. Dex 6 is compatible with Dex 3. You don’t need to change all the fluid out in order to run 6. But don’t use Dex3 in a trans designed for Dex6. There’s so much disinformation out there. I’m not going any further down that rabbit hole. Reminds me of the slip/ non slip additive in the G80’s. So many opinions, so few facts.
drackill1
