MassHoe04
Western MA
What I need to do... I noticed that the little lightbulbs in my driver's side switches stopped working. I found a YT video of how to replace the bulbs, but his method is rather primitive.
There must be a better way.
Probably best to go with new replacement switch... Ages eventually catches up with these anyway. By the time you get through replacing bulbs inside, it may not be worth the effort.
Merc1973
Maryland
Doing NNBS front brake upgrade. Just ordered this and some replacement rubber lines.
Mudsport96
40.923,-89.488. Illinois
I tried this, and for some crazy reason, it just would not work… so I installed a new head unit. Wanted that -eventually- anyway. Lol
I was all excited, then when i hooked up my phone nothing happened. Check and double check... then i remembered my headphone jack doesnt work on my phone. So i had to go get a bluetooth receiver to plug into the aux jack.
GreenTahoeZ71
I put a new compressor and accumulator and orifice tube in this weekend.
I also redid the compressor connector and the refrigerant pressure sensor connector too.
Purged with nitrogen, vacuumed and weighed the charge back in. Nice and cold. The diode had failed and it was sending a volt spike through the system when it world disengage the compressor clutch. I'm gonna clean the evaporator coil tomorrow with that cool automotive foaming coil cleaner that you feed the little tube up the drain tube and spray.
Dropping it off to get the CV axles and wheel bearings put on tomorrow morning. Gonna clean the coil when I get home.
Tssonebay
