SilverSport
replaced the blower resistor on my 2005 GMC Denali...I had lost complete fan speed control (it has been having a mind of its own since my purchase in June) this week...
appeared to be one of 3 fixes...the blower worked sometimes so I didn't think it was that...it could be the blower resistor or the HVAC control module and that was far more expensive so I tried the lesser priced "fix" knowing I could return the resistor if that wasn't the fix...
not happy with buying a no-name part but the OEM doesn't seem available (mine had the 3 prong connector in back for Auto HVAC) but so far I can turn the fan on and off as well as in between...
pic of the OEM part
project_x
I cut out my passenger rocker and replaced it with fresh metal. I cleaned all the loose rust off, used Corroseal on the inner rocker and used POR-15 inside the cab corner.
I welded the new panel in place. Ground down the welds and used a little Bondo to smooth out the transition from the fresh metal and the factory rocker (profile is slightly different).
I then masked the cab corners, fenders and inside the cab. I primed and followed up with bed liner.
I plan to install Trail Armor plastic rocker covers, once I finish the driver's side.
PSA: Don't put Corroseal on anything you are planning to weld ..it takes forever to grind off... super tough.
project_x
Also,
PSA: after you finish for the day...and all the sheet metal is ready and fitted. Make sure you move it before you move your truck!
I had to use the drive side piece and redo it... the bends were too much to straighten...
ivin74
05 NBS Nali
Htown, Texas
Wanted to change the look of the rear tail lights, so last week I bought the C bar leds. The new ones came in today, if I have time tomorrow I'm going to install them.
Might sell the old rear leds tail lights.
Finally, I installed the C-bar LED tail lights.
ncalvo
FL
Man rockers are no joke, so much time and effort.
I still have small holes to patch up on my passenger side that I have been putting off for months.
project_x
I just cut off the driver's side today and will put the new one on this weekend....
Sam Harris
Texas
Put in a half tank of corn, actually E70, to top it off. This station is super-consistent with the ethanol percentage, it's even marked at 70% on the pump. Can't beat the price and performance!
Is that the Alta station, or somewhere else? Boy, do I miss my corn gas!
On another note, I finally decided to pickup a 5.3 from an ‘04 Burb… I really wanted a 6.0, but they’re getting harder to come by, and spendy.. got this one for $500, and was a good engine when pulled, so hopefully in decent shape. I’m planning to bore it over a bit for some extra cubes.. so far, it’s not too bad as far as bolts / corrosion. There were 2 broken exhaust manifold bolts, but the rest came out fine. Heads were definitely dirty.. not too good about the oil changes apparently..
emfadz
