Grimes
Oops.
Exhaust resonates around shift, can't seem to pinpoint an RPM. The resonating is a "pinched" sound. Its not awful, someone wouldn't notice it if they didn't drive it for a few years then have a sudden change, but I certainly notice it. Any suggestions? Haven't had a chance to mess with it yet.
Fosscore
Did the HD bumper cap and grill today. Also ditched the DRL's and converted them to turn signals/running lights to match the outer ones, and installed LED's in all of them. Just waiting on the bowtie now. I might get a cowl hood eventually, but not an HD hood, I don't like them.
Nice. Like that stance.
redemn93
Jupiter, Fl
i have djm lca with bilstien shocks up front. It better due to the fact the steering isn't so soft anymore. Before wheel would shake and move a lot more then it does now. I noticed the difference right away which helps with the ride. Also tracked better not all over the place when I hit bumps because there was resistance on the wheels now. Before my wheel was soft easy to move. Way better now. Hope you follow that lol.
Billy
awesome. im ordering the resistors today. i did some research though and found the message will still be up if the compressor is unplugged. my compressor is sitting in a landfill somewhere. any idea which wires to use from the compressor harness to install a resistor there?
owl_93
Finally got her back from the shop. I removed my single row 20" led bar and replaced it with a 21" double row Amber/White bar. Really happy with the result. I have it angled higher up than the bumper flood and lower than the roof hyperspot.
05Yukon23
Arkdelphia, AR
Cleaned up the front valance and painted black, new fogs installed, tires came in the mail and TPMS sensors. Now waiting for Friday so I can get the tires mounted and balanced. Also installed a button so that my backup can comes on whenever I push it without shifting into reverse. ImageUploadedByTapatalk1432077746.630028.jpg ImageUploadedByTapatalk1432077549.680663.jpgImageUploadedByTapatalk1432077559.914138.jpgImageUploadedByTapatalk1432077572.214991.jpg
Yngbld32
Hoover,AL.
No oil psi on oil psi gauge. Replaced oil psi sensor. I then found a quarter size section of paint gone on my roof. Son of a *****!!!!
clandr1
Dallas/Fort Worth, Texas
I replaced my rear window wiper arm since the original was chipped, weathered, and had lost spring tension. Super easy replacement - it only took me about 5 minutes.
Marv02
Ca
Transmission Cooler
Installed a Haden 405 Transmission cooler today.
Lets start if I measured first before what would fit easy that would been the smart thing to do.
I end up Ordering a Haden 405 cooler the larger one hey I figured there was going to be enough room LOL.
My Yukon has the Tow package on it and it has the Factory Trans cooler already.
The plan was to Piggy back the new one after it ran thought the OEM cooler.
I was planning to mount the new cooler to the right side of the OEM cooler Not going to happed the New one was to large to make this work.
I end up moving the OEM to the Right side and placing the New one in the center where the OEM was mounted.
I had to Fab up mostly all new mounting points and modifying the stock ones to get every thing to work it was a 4 Hour job.
But every things works fine now.
If I use the right size from the get go It should been a hour job at the most.
7amannnyy
