Woodblocker55
Woodblocker- what year and drivetrain do your have?
Tap a talk screwed me up I ment to post in GMT800
It's a 2006 Yukon XL 5.3 4:10 and hd towing package . Anyone know best air bags ? Is it worth $10 for Firestone air bags for rear ? I have towed with a 2001 suburban LT with HD towing 3:73 12,000 lb trailer. So ya I'm guy that tell ya the limit of a suburban/ Yukon .. my Yukon XL will be the best it can be . I did find out suburban 2001 did great at 9000 lb load it's weakness was it needed truck tires P tires are just to soft . That's where set of towing tires came in for the 2006 Yukon XL it fix that squishy problem ... I was using weight distribution hitch .. so I need air bags on 2006 .
Sent from my LGL84VL using Tapatalk
St. Louis
I have the Airlift bags on my 2001 SLT
Mounted the inflation valve through the bracket that has the 7-way connector
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Woodblocker55
On second coat of filler primer .. has anyone wet sanded color ( going to be black ) before hitting with clear coat .. or after primer do I hit with black then hit with clear coat .. steel rims are being a bit tricky with cooler weather.
HiHoeSilver
Away!
Chicago
If you need to sand the color to fix something, you're supposed to shoot it again before clear, afaik. Then sand the clear.
Woodblocker55
I'm going to try that .. and way I understand it I can use like 2000 grit on clear coat . Then hit with polish . I need to get one of them handles for the spray can to get color perfect for clear coat ..I will send pictures either way Doom or success. [emoji41][emoji106][emoji1258]
wiser1
