George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
So basically any tire shop should be able to fix it pretty easily/cheaply?
Its a fairly easy fix however with the chrome wheels once it starts it’s usually an ongoing problem. The corrosion works it’s way under the chrome and causes a leak path. Back in the day we had some waxy grease stuff we would use to help seal out the moisture and slow the corrosion.
Yeah at least on mine it’s an easy fix- they just pop the bead, clean the bead and reinflate. If your chrome is peeling off the bead I’m sure it’s trouble. Yours might just be around the weight though, hard to tell until the bead is broke so you can see.
PG01
Up here to the right
Oh, guess it would normally run across the enrire cowl?
I didn't know that's what those types of lights were called
Well it’s any light mounted there to illuminate where the headlights don’t shine, as in ditches to your left or right...and so forth so on etc etc etc
Sparksalot
Bastrop County, Texas
@gooffeyguy this here. Mainly for off highway at night. Or rural highway in deer country.
the pair I have coming project forward and to the side a bit as well.
Sparksalot
BMPGBH
