Just Fishing
Can't fix stupid
Utah
Hell naw. This was during the summer, of course. That was a loud and hot drive back home. Had the windows down, but the wind was just hot, wet and sticky.
Got me thinking about doing the ac compressor again.
July is going to be a trip to the coast in the hoe.
It would suuuck to loose ac in the middle of it.
Yeah windows down doesn’t help when it’s hot and humid af.
1BADI5
DMV
So converters for the 6l80
Looking over circle d's stuff,
I see a good looking option for under 1k
https://www.circledspecialties.com/gm-300mm-hp-6l90-ls-torque-converter-2
states a twin disk lockup
And then the rest appears to be over 1k
Like this option with triple disk selected is over 1300
https://www.circledspecialties.com/6l80e-pro-series-265mm
I suspect it's overkill for my intended use.
What one is everyone buying?
:yuno:
Unless your going to build a 1000 rwhp rig, no need for those big twin disc verters.
I got the Circle D 6L80 3200 stall, only option I pony'd up for was the billet where that makes the converter stronger.
Around town, drives like a stock converter...............now when you put the pedal down, its fun. Its like the best of both worlds.
wjburken
Eastern Iowa
One should NEVER go on a road trip with no tools.
I wonder if they make an adapter to go from the lug nut size to the crank bolt size. With this, you could use the factory lug wrench or one of those extendable lug wrenches as a long-handled wrench. All you'd need is to weld a 22mm bolt head to the back of a 24mm socket, maybe a cheap cut-down HF impact socket.
Or....take a 24” long 1/2” drive breaker bar and a couple sockets.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I can make an adapted like that or just have the breaker bar and socket. There may not be room for the lug wrench anyway.
George B
¯\_(ツ)_/¯
I need to setup a dedicated kit that stays in my truck again.
Jhawk79
