08z71bgm
Long Island, NY
Been searching for tires for the hoe for a bit now. Can’t seem the find something that jumps out and says THESE ARE THEM!!
265/65/18
Looking actually for a winter tire that will see occasional snow. Long Island doesn’t get crazy snow where I need an aggressive AT muddier tire. By the time I go out the roads are plowed and icy and wet and cold.
Any suggestions?
Also picked up a bunch of lumber today to for a storage project. Almost done will need to get more tomorrow.
Got the front rotors swapped and sway bar lubed, boy those front caliper brackets were f-in tight, tighter than I had the rear ones, couldn't find specs for the Baer but everywhere says 85lbs which doesn't seem right so there back to f-in tight lolView attachment 354932
The fronts are always torqued higher than the rears so if the rears are kinda f-in tight then the fronts need to be f-in tight so I say you’re GTG!
the bolts are bigger on the front Baer brackets, 22mm -vs-18mm stock, what do the wilwoods torque at?
Ls1nica
My a/c started blowing hot hair. I had to go buy freon. I didnt know they had switched out of R-134. Which i guess its more expensive and uses a different hose.
CocoH103
