PG01
Up here to the right
I changed the plugs in the Yukon today. It wasn't as bad as I thought it would be. Even #8 was manageable without pulling the fender liner and other shenanigans. I used a 1" extension on the plug socket which gave me room to clear the exhaust manifold on one side and the firewall heat shield on the other.
Here's what it felt like:
Did mine the other day, I had plugs, wires and 02 sensors to do so I killed a few birds with 1 stone and rotated tires too. While it was up on jackstands I just yanked the fender liners and did it all while sitting on my fat a s s and I didn’t have to lean over the fenders or play twister and cry about my back later on that night.
89Suburban
Bull in the china shop
SE PA
This video mentions a TSB for the ECM program update for 08-11..?
So this video and that TSB I looked up says 2008 and up. Mine is 2007. Does it still apply??
One thing I see I did wrong, according to that '08 and up TSB, was when I installed the TPS on the TB with the throttle plate in the idle position. The TSB says install it with the throttle plate in WOT.
89Suburban
SE PA
Unless I'm not remembering correctly, didn't you say you pushed or otherwise moved the wire harness at the TB and the fault occurred?
Yes but only one time. This thing is bewitched. Could have been coincidence, could not.
mikez71
Seems to only say 08-11
Maybe the throttle plate angle during assembly still applies. ?
foodboy767
