What do I need to reset codes?
Mean_Green
I have a recurring P0442 code for 'small evaporative emissions system leak'. Auto stores will sometimes reset it for me, but they don't seem to want to and it just comes back after a couple of months. I don't know what causes it and don't have the money for a shop to fiddle with it for days to rty and find it. There are no operational problems that I can see. Runs and starts fine.
Padraig
Padraig
NickTransmissions
Sin City
The transmission bench
Have you fixed this yet? If not, wonder if it's simply your gas cap needing to be replaced. If that's it, should clear on its own once a new cap is installed.
Mean_Green
Mean_Green
I got a new gas cap because the previous one had a lock that didn't always seem to work quite right. This one does not lock. Code issue didn't seem to change.
preinternet
The parts store kids don't test or clear your codes (properly)hell 98% of them don't have a clue about anything gone are the days when you had to actually know something about cars to work there you can get a cheap scan tool for around 30 bucks it will help
preinternet
I did not notice what year you have if it's OBD one discount negative place a jumper between poss -&neg.. let it sit for about 20 min it will drain all stored electric in PCB ecm (etc) when you reconnect turn key to run let sit for a min or two before starting
This sounds totally unclear but seems to present a fire hazard. Not sure how one "discounts" negative.
preinternet
Removed neg from battery place jumper wire with alligator clips from the disconnect neg term to the still connected poss wire leave like this for ten min it will be not harm the truck it will not blow up it when done just like this will drain the storm energy from all!!! Controllers sensor's etc
TheShiznit
