What have I done?!
Screwd up 6
That's weird. Have you tried to disconnect battery for a bit to see if computer will reset. I really wonder if battery is drained beyond dead. Voltage didn't even move when u tuned the key
cruisingslow
cruisingslow
Oklahoma
Well I left it alone for awhile and just went out there and the key fob worked and the normal lights came on that normally do when you unlock but they were extreamly dim and turned off shortly
Screwd up 6
You can still save. Will just take A while to charge up again. Does it At least have a voltage and stuff when u turn the key to on with cables connected
cruisingslow
cruisingslow
Oklahoma
Last night I had it hooked up to my jumper box and it wouldn't start. This morning I went and swapped out the battery terminals hooked up jumper cables and let it sit for about 5 minutes and then it fired right up. Just in time to drop it off for its appointment this morning to have it tinted also. The old battery terminals where pretty covered with corrosion, I guess it was just a really inconvenient time for the battery to start acting up. Thank you for all the help Screwd up 6!
08grey
That was the car gods saying hey you!!!!!!! before you figure out how to turn up the system louder fix my heart cancer.
Screwd up 6
So maybe your wiring aux will work! Give it a try...just unplug the battery while you are working so you don't trip a fuse or drain it haha.
cruisingslow
cruisingslow
Oklahoma
Got it all finished and working perfect! Probably the best 3 dollars I have ever spent. Also picked up a new battery today.
Bubnasty94
