What is this awful creaking sound?
GMT800 SUV/Trucks
I’ll try to get another video today but it does it when I turn the wheel, though it’s more pronounced when I hit a bump while driving
This new info is more detailed. I still suspect a ball joint or bearing like Chris said. Does it make a difference which way you turn? Is it more pronounced when over a bump going straight or over a bump and turning at the same time? If so, does it make a difference on which way you are turning and how much you are turning?
mattjones
mattjones
VA
Looks like it was a ball joint. I ended up ordering a grease gun on amazon and following this guide to grease a sealed ball joint: https://www.suspension.com/blog/how-to-grease-ball-joints/.
They didn't look to be torn or anything but after greasing them up it seems like the squeaking is gone. Here are some pics of the upper and lower ball joints:
I also noticed the tie rod end seemed to be covered in grease like it had been leaking or something so I cleaned off the zerk and greased it up as well. Didn't notice it until just now but it looks like the dust shield might be broken right next to the tie rod end.
I'm assuming the ball joints will have to be replaced eventually but hopefully the grease will buy them some more life. Truck is at about 86k miles right now. I noticed the ball joints on the passenger side have zerk fittings so I'm guessing the previous owner had them replaced at some point.
Dust shield doesn't look broken at all.
Make it a point to at least check all the joints with zerks at each oil change. You don't need to pump the boots so full that they leak and you may not need to add any grease except to the TREs if they're leaking. AFAIK, the only other possible zerks would be the U-joints if they've been replaced with aftermarket greasable joints.
GMT800 SUV/Trucks
Alot of times when you see grease build up around the grease zerk it is when they are clogged with dirt and the grease takes the least path of resistance. The zerk should ALWAYS be thoroughly cleaned before shoving grease in them. You can see how that lower ball joint boot is collapsed and cracking. Yea, when you do grease a zerk just fill the boot but not to excess where grease comes out of it. That can create a path for moisture to get in there when the grease falls off.
That dust shield looks fine. I bet the other side looks the same. That notch is for when the steering could be at full crank/turn and the suspension is jounced heavily and it gives clearance for the should of the tie rod to move.
mattjones
mattjones
VA
No zerks on the u joints. I actually looked into replacing them when I first started hearing the squeak and thought it might have been a U joint causing the sound. It wasn't until the squeak got a lot louder that it was clear it was coming from the front driver wheel. But I actually dropped the drive shaft to look at the u joints and they seemed to be in good shape.
Ah okay, makes sense. I didn't even notice the little cutout until I was looking at the picture. All of those pics were taken before I greased them. I pumped until I could see the boot filling out.
GMT800 SUV/Trucks
The boot is full when bulging round. I have even filled the boots and then started the engine and cranked the steering left and right 5-6 times each way and then could see the boot bulge was flatter and then I put more grease in. Really no need to grease till pushes out. Can create a moisture path, as I stated earlier. I have even seen old/cracked rubber ball joint and tie rod boots split open when have too much grease in them.
mattjones
mattjones
VA
No, I meant "filling out" like the boot was expanding. Not like grease was spilling out of it.
GMT800 SUV/Trucks
I was going off the pic that showed all that red grease spilled out or is that a snap on cover for the brakes? If so, BELAY MY LAST!"
Isn't it great how they ALWAYS leak out of the side you can't see? You'll be pumping along and wondering why the boot isn't swelling any and think your grease gun isn't pumping. Then you see a giant glob of mixed old and new grease fall and splat on the floor.
GMT800 SUV/Trucks
Yea, fun times. Especially if it gets on brakes and other close items and you have to clean up. Those shop air powered grease guns can create problems if you are scratching your nuts when you should be watching that area/boot.
Smityinms
