stock height is 2" lower as well*Hey guys I purchased a Z71 and didn't realize it but it has a lowering kit on it. I am researching putting it back to stock height but I wanted to see if you guys can tell me what kind of lowering components might have been used to lower it.
So far all I can tell is that the rear springs are blue and probably lowering springs, there are no rear shock lowering brackets so the rear shocks mounts are stock. I looked up front and the front shocks are red. I cannot tell if there are lowering knuckles.
Here I have attached a picture of my white lowered Tahoe on 20 inch wheels as well as a stock z71 with 20 inch wheels for reference.
View attachment 242584 View attachment 242585
it increases the frontal area.Lowering does not lose MPG.
What do you mean by the stock height being 2 inches lower?stock height is 2" lower as well*
*on the SSV/PPV and H trims... you will probably lose some mpg like 1mpg or so...
one of the benefits is increased stability on pavement.. plus it's more convent putting a drunk suspect into a lower chassis
@BG1988 Oh you were saying that the PVV model is 2 inches lower than stock? How much higher should the z71 be over stock and what determines the ride height of the factory trucks, is it the struts or the springs?there is multiple "stock heights" depending on the trim one has
Z71 slighty higher
LS/LT/LTZ 'normal'
HY1/HY2/PPV/SSV lowered
this is a good example
@BG1988 It has the z71 cluster, fender flares, nerf bars pretty much everything that would indicate it is a z71 but who knows74.61 to 74.84″ HY1-2
74.6-77.0 in SSV
73.9" PPV
76.9 " LT/LTz Z71
4WD = 77" it's only a fraction of an inch.. so they did lower it or it's a fako z71?
it has the Z71 cluster correct?
