Radio and interior lights won't turn off...
ivin74
05 NBS Nali
Htown, Texas
Not sure if anyone else has had this issue but here's my problem and how I fixed it. I couldn't find anything online about this so hopefully this will help someone else out!
I drive a 2004 z71 Tahoe. I noticed that upon removing the key from the ignition then opening the driver door that the radio would continue playing music and the interior lights would not turn off. I would have to get out, close the door, open the door and then close it again for the anything to turn off. When I would open the driver door the interior lights would not come on. The door ajar warning wouldn't react... etc.
After looking over some wiring schematics I narrowed the root of the issue down to a component of drivers door latch assembly, the mini wedge switch. This door switch is an input to the BCM telling it that hey I'm open or hey I'm closed.
I removed the drivers door latch assembly which has three harness connectors that plug into it. The connector with the dark blue and grey/blk wiring is for the mini wedge switch. I disassembled the latch assembly and quickly realized the root of my issue.
Here is the complete latch assembly
Remove the metal strap from the top and the two small screws closest to the top
Pop free the yellow arm
Seperate the the two pieces
Remove the white plastics backing plate
...continued.
My truck just started doing the samething, i'm going to do the same fix. Great write up M1 gunner
M1Gunner
M1Gunner
Gainesville, Fl
I did the mod and my door lights are working again. Please be extremely gentle with removing the gear cover, i used a utility knife to cut thru the glue.
Awesome! Glad this helped and yeah you gotta be very gently with some of the pieces pieces process!
warndogg
Thanks for the write up! I have been needing to fix this for a few months. I had already bought a used latch $50 on ebay before reading this so I cleaned and used that one. Now I got a spare. Oh well.
bl74
