AlejandroDinero
Destin
Swapped out Headunit’S
SRQYukon
Sarasota, FL
Don't do the torsion keys if your dropping it. Ride will be ruined. By the way, looks like your ordering for a 4x4 and I thought you said it was 2wd.
AlejandroDinero
Destin
Make, model, install details. Daylight pics.
Bizine-10.1 inch screen 2GB Ram 16GB Rom. it isn’t like a normal double din at all. The only thing needed was the brackets from the factory and wiring harness’s. With the brackets you have to install them as you were pushing the unit away from the dash to clear the bezel with the screen. Basically modify them as you see fit for your installation. It is OBD2 capable so I ordered a mini Bluetooth OBD2 scanner to get live diagnostics through the unit. But for some reason it isn’t turning on in my Tahoe, I tried it in my wife’s X5 and it works so i don’t know what’s up with that. But I’m a big you get what you pay for believer to the max! After reading reviews and everything I decided to give it a shot since my Pioneer AVIC-X920BT isn’t doing it like I thought it would for me.
HiHoeSilver
Away!
Chicago
View attachment 236561 View attachment 236562 View attachment 236563
Cool. Check your cig lighter fuse. The OBD port is on that circuit.
whittlc
