Well that sux!One at a time, I swapped both the starter relay and crank/run relays. No bueno.
Finally opened the catchcan..... This was after driving, but still..... It was like soft-serve ice cream..... Contemplating flushing it out to see if something is clogged. Just odd that is has not drained in the past two oil changes.View attachment 271299
Sent from my Pixel 3 using Tapatalk
Damn right, and it's better than yoursDamn, Chooch, did that bring all the boys to the yard?
Did you try jumping the pins and see if the starter works? also reach under there and smack it with a hammer a couple times that may get you goingOne at a time, I swapped both the starter relay and crank/run relays. No bueno.
Decided I didn’t want the front stabilizer bar anymore. Sprayed lots of penetrating oil. One bolt I was able to remove by loosen a bit, tighten a bit, etc. One bolt broke. And the other two I rounded the heads. Cut one with my Sawzall until I had to finish for noise concerns for my family.
Yeah...that’s an oil leak.![]()
What made you decide to remove the sway bar? I consider it a safety thing myself.Decided I didn’t want the front stabilizer bar anymore. Sprayed lots of penetrating oil. One bolt I was able to remove by loosen a bit, tighten a bit, etc. One bolt broke. And the other two I rounded the heads. Cut one with my Sawzall until I had to finish for noise concerns for my family.
