I think I figured it out. I had to bang the new lower shaft on because it wouldn't go on, so I used the old upper shaft to bang the new into place. I inserted it correctly, but I hit it too hard. It pushed the new lower into place, but the old shaft went in too far, thereby stretching the new inlet a bit. I don't see a way to close it up some. If I took it apart I'd be facing the same issue that caused the problem in the 2st place.
I tried posting vids but it won't let me.
blueinkd
Excuse the ignorance but what led you to completing this repair?? I have seen several discussions on upper and intermediate shafts in the recent months. My rig showing upwards up 245k miles and if I should replace before major failure I'm all for it. I don't like letting things completely fail before fixing them. I'm currently waiting on my front brakes to at least squeak or crap out before the 4 pistons calipers get bolted on.
ks03
Fool Excess Member
Not sure what you’re thinking to close up. I wouldn’t take it apart, just loosen the bolt at that connection slightly, try to align the 2 shafts, and retighten
The new parts weren't really expensive, so I just decided to get them. I do have a little steering wheel play, so I was hoping by doing this I'd reduce the play a little. I also might adjust the steering box, but I'm a little hesitant to do that. Too tight and you could destroy the gears inside.
I did try to do that--same thing, no change. I think the wobble came from using the old shaft to bang the new lower onto the steering box shaft.
ks03
Fool Excess Member
It’s probably not for the best, but I’d probably loosen the bolt a bit, rotate it where the high point / largest part of the run out was facing straight up, and gently beat it into submission.
Won't work in my situation. I just put everything together and said fu*& it!
ks03
Fool Excess Member
If you think your steering box is loose, what’s the downside? Worst thing would be having to replace it vs. living with it loose and slowly getting even worse. I haven’t adjusted many, but when I’ve adjusted them by hand to have a minimal amount of slop I can feel at the gear, when test driven they feel weird and I end up loosening them up a surprising amount to have the best feel.
raptormc
