Installed my Fox 2.5's briefly. With the preload set this low we are still almost maxed out. Was hoping to bring the truck down a half inch from where it sat with the 2.0's and instead raised almost an inch. Took measurements and they are back in the box en route to Accutune for 600lb spring swap and a re-tune.
The good news is I've gotten pretty quick at removing and installing the front shocks with all this practice haha.
where do you go off-road ?
I have family out near Stoddard Wells so we spend the majority of our time out there roaming around and taking the kids rock hounding. We've also explored a few trails in the mountains. I always recommend Burns Canyon. Mellow trail that transitions from mountain to desert, whole family loved it.
Other than that I always try to find something for us to explore on the TrailsOffroad app when we are on vacation or on day trips. Last year we had the opportunity to see some beautiful trails in Arizona.
NOPROBROBB
UTAH
Not a fan of the glossy wood so I started to work on covering it up with a vinyl wrap. Wasn’t sure what to use since I’m trying to get rid of fake wood and am not crazy with a fake carbon fiber all over either. This was a bit glossier than I was hoping but feel like it turned out pretty good. Now just got to get all the door switch bezels done.
Edit: this is what I used if interested. VViViD Black Stealth Plaid... https://www.amazon.com/dp/B0B7ZGHK19?ref=ppx_pop_mob_ap_share
Sparksalot
Bastrop County, Texas
That looks pretty cool.
Just Fishing
Can't fix stupid
Utah
I need this but in plaid. :think:
Love this! Would you mind sharing a link to the vinyl? Not a fan of the fake wood either.
RooTBeeRthe1st
Is it safe to assume that the LT starters are more robust for doing stop/start duty?
He told me they were a bigger better upgrade for ls's, and bolt on.
However RockAuto still has 1.4 KW and 1.7 KW options.
So I'm not sure, I didn't actually look at part numbers because I literally just bought one and don't plan to buy another one for another 180,000 lol
But considering the LT engines are higher compression which obviously takes more power to turn over, and I suppose if some of them have start/stop they might be a little more robust.
RooTBeeRthe1st
My 3" kings unfortunately had a similar issue, and I haven't yet corrected it despite them only being tens of miles away(Garden Grove).
I basically have zero droop, it was like a 3 in lift in the front with them lowered all the way down.
Which unfortunately also has meant that my front axles have actually been rubbing through the aluminum on the lower part of the coilovers for all these miles.
I need to get shorter springs eventually.
Haven't been out to Stoddard in a long time!
Need to make a trip over to slash x for some chili cheese fries and cold drinks.
We usually go up off of 395 near Randsburg, was supposed to go out the 20th last month and had other priorities, next trip is Thanksgiving.
Your mountain and desert Trail has me intrigued though! I have to look that one up now and make some plans.
Nice choice! I did similar, except that it was supposed to look like granite or marble, but in a vehicle, it ended up just looking like black and white camo.
Although I just had the basic silver trim rather than the wood, but the wood is hideous to me
Williammdzialak80
