J-Herkel
- Joined
- Oct 19, 2024
- Posts
- 22
- Reaction score
- 50
Getting to the point..
2007 Tahoe LT 197k miles.
Suddenly would not start back up today after running fine for years and even started up 3 times prior today. Battery is brand new, took it out and tested it at the auto store. It's good. Alternator is fairly new. Starter was tested and is good. It will crank with a jumper wire in the relay. Obviously no signal from relay to starter solenoid. Not sure where the sending wire from the starter relay comes from. ECM? Ignition switch? Everything else in the vehicle runs perfect. Radio, lights, power windows, all strong. Just when I go to turn the key over to crank, nothing. And it was sudden. Any ideas?
