Painted my rear seat with SEM looks 100% better now have to do the other side.
Why did I paint my seats you might ask, well that's a long story.
When I got the truck the drivers bottom was ripped and the passenger bottom was close to it. I knew a detail/paint correction, kinda do it all guy who said he could fix the seats - yeah this is where it all went wrong.
So I go to pick it up and he replaced the drivers cover and used basically a type of bondo for leather on the passengers seat, the kicker was he says you can't get the original color int dye so he had to "custom" mix some dye....
So the color was close but has too much blue in it and now if I change any part the color won't match hence why I am painting the rear because yes he painted the rear to match the front. Plus I am sure he used paint which is why the drivers seat didn't last a year before cracking and the top cover is cracking as well.
So when I redo the leather on the front I will also need to fix all the overspray on the plastic molding pieces as well.
Depending on what product he used on the seats it doesn't last. Also the repair on the seat won't last either. I used to repair seats for dealers. They still sell the exact leather colors for the NBS. Did you use SEM products?
Here's the kind of stuff I used to do.
latvius
Ariton Alabama
Good work! Yeah I used SEM and when he told me he couldnt get factory color I knew he didn't know what he was talking about but by them my seats were already painted so....here I am LOL
BigDogYJ
Earth
I need to fuel up and wash the wife’s 04. And replace the parking brake release handle. I’ll see if I can get to that tonight. It’s getting cold.
Got it fueled up and washed. I’ll attempt the parking brake handle/cable tomorrow.
I changed the abs wheel speed sensor that I messed up and forgot to tie it back so it rubbed through the wire. Yay no more abs light.
Was it a GM hub or aftermarket? I'm having a similar issue. I found out you can't use an GM abs sensor in an aftermarket hub, and same other way around. Sensors won't work.
ncalvo
FL
My driver side blend door is acting up, of course it has to happen when its cold out, I already know my heater core is on its way out.
I am looking to get all the parts for everything inside the dash and do the heater core, evap, blend doors, is there anything else I should replace while i'm in the dash?
Have you tried to do a factory recalibration on the hvac? Might get you through the winter with working heat coming out all of the vents.
Davoe1975
