opfor2
The below paragraph is from the GM service manual (see attached for the full version) and the way I'm reading it is that if you had any of the listed DTC, a P219A would not set does that also preclude the code from resetting if the listed DTC's are set?
Conditions for Running the Diagnostic Trouble Codes (DTC)
*DTCs P0030, P0036, P0050, P0053, P0059, P0101, P0102,P0103, P0106, P0107, P0108, P0117, P0118, P0128, P0131, P0132, P0133, P0134, P0135, P0151, P0152, P0153, P0154, P0155, P0201-P0206, P0300, P0301-P0306, P0411, P0412, P0418, P0442, P0443, P0446, P0449, P0452, P0453, P0454, P0455, P0496, P1133, P1153, P1516, P2101, P2119, P2120, P2125, P2135, P2138, P2176, P2431, P2432, P2433, P2440, P2A00, P2A03 are not set.
* The device control is not active.
* The intrusive diagnostics are not active.
* The engine overspeed protection is not active.
* The power take-off (PTO) is not active.
* The traction control is not active.
* The fuel control is in air-fuel Closed Loop.
* The system voltage is more than 10 V, or less than 18 V.
* The engine run time is greater than 100 s.
* The engine coolant temperature (ECT) is greater than -20°C (-4°F).
* The engine speed is greater than 425 RPM, but less than 6,000 RPM.
* The mass air flow is greater than 25 g/s, but less than 510 g/s.
