BREAKING: GM is officially recalling the L87
KMeloney
Agreed. There is probably a whole lot more to the manufacturing defect story than is currently known outside of GM technical staff.
When I called a local dealer about the recall, the service guy made a comment about there being dirt/contamination in the production process of the metal of these engine parts [that is causing the failures]. Now, I don't know if that's his interpretation of the terms used in the bulletin(s), or whether he got that info on good authority. Well prior to the recall coming out, though, when he had 3 trucks at the dealership waiting for new engines, he said that the failures were due to [a run of] poorly manufactured parts. To me, that checks out/is the culprit here.
jfoj
And there were no mothers of football players on K2 with a 6.2 engine and 0-20 oil, or did they drive differently before? Or maybe the fuel was different, which was less irritating to the oil
Big difference, AFM vs DFM and mostly 8 speed transmission.
KMeloney
Exactly. I'm not a soccer mom, and I have only a 10-minute commute to work. The ideas that I shouldn't be warming up the truck before I get in it to drive to work/anywhere, and that I shouldn't drive it for only 10 minutes may be decent preventive measures toward staving off engine failure, but you can't convince me that these (and all engines, really) were designed to NOT be warmed up first, and to ONLY be driven more than 20 minutes at a time.
I think the evidence is pointing to a run of engines built with a run of faulty parts.
GMCChevy
0W40 will also become fuel diluted just like 0W20, it just has a far bigger safety margin, before the viscosity gets equal or below the viscosity of fresh 0W20 oil.
Again, it has a lot to do with how the vehicle is used. Too many Soccer Moms running too many short trips in the colder months and even the warmer months, but the Soccer Mom mobile maybe gets enough miles for a single oil change a year. If I would have run my kids to school they are all within 1-2.5 miles from my house. So just think about how this would impact any vehicle much less something like these trucks that take 30 minutes of driving for the oil to fully warm up.
Far different than most trucks that actually get worked and have miles put them. Some trucks are play toys, many are working trucks.
I would love to see the distribution of engine failures of SUV's vs Pickups. My gut tells me based on reports I have read is probably around 4-5 SUV to pickup, but this is my gut based on reports I have read. Maybe the distribution is equal to the number of SUV to Truck sales? Who knows.
I would guess the failure rate is similar. A large amount of trucks get used for the same sort of driving as full size SUV's. The days of trucks being primarily used for work are long gone.
Marky Dissod
This suspicion should always be near the top.
Don't forget that they will also recommend 0W20 instead of 0W30.
Don't see why motor oils that work well in the L8T as well as the LT1 / LT2 / LT4 / LT5
would not work well in other GM 6.2L V8s (not to mention other 5.3L V8s).
jfoj
It doesn't matter, afm/dfm works on the highway, and in your example about footballers' mothers and short trips to school from home, afm/dfm doesn't work
AFM and DFM does work both on the highway and all conditions. It works even as slow as 20 MPH, I have monitored and you can even hear the changes at the vehicles drive around if you are behind them. You CLEARLY do not understand how AFM/DFM functions.
The difference is DMF can operate on as few as 1 cylinder, AFM operates on as few as 4 cylinders. Seems the MAJORITY if the failures are at highway speed when the DFM is possibly trying to run on as few as 1 to 3 cylinders and is actively dancing around during all of the combinations. Putting all the load on between 1 and a few cylinders.
Lonny
Just talked to my dealership about my Escalade. According to them, no parts are available right now, no work can be done right now, the dealership cannot do anything right now. They aren't going to do anything for the moment. The guy told me to wait until I receive a letter in the mail with further instructions.
Meanwhile, I've got an alert in the MyCadillac app saying "dealer will inspect and as necessary, repair or replace the engine??!?!!?"
What the hell are we supposed to do?
blanchard7684
Senior Member
If it were me I'd be doing a 0w40 swap this weekend. It is the easiest thing end user can do to improve their odds against a failure.
dcobbs17
