Question for you E-fan guys
oreowizard98
Monroe NC
This is something I would like to do aswell. Im new to the site and Im still gathering info. Im a big DIYer. I rebuilt the engine in my T/A so I think this would be a breeze. Just to get this straight, I want any 05+ dual e-fan set up the harness and pulley? Then I need to have a tuner turn the pins on? And possibly drop in a lower temp t-stat? Do I have is pretty much covered?
Max
Mile High
Denver
I wouldn't worry about tstats, just make sure your charging system is up to the task.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
X2 I wouldn't worry about a t-stat, if anything, just an OD pulley for your alternator, or a larger alternator.
oreowizard98
Monroe NC
is that not in the package that Jenna offers? The gold looking pulley. I'm thinkn of beefn up the amp. Going to run a small audio setup
coopiesb
wichita falls, tx
ok found a fan kit and its asking if i have a 28" or 34" radiator... im not sure does anyone know i have an 2004 hoe
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
If you have a towing package or a Z71, then you probably have the larger one.
coopiesb
wichita falls, tx
no z71 or towing......... so you think the smaller one?? maybe i can wait until the tune and let justin to take a look and tell me what i got.....
tybardy
everyone needs a Hoe
Gilbert Arizona
you can always pull a tape measure on it...
another questions guys. can you get a different size belt and disconnect the clutch fan from the belt completely? seems like this would completely eliminate the drag on the belt
coopiesb
wichita falls, tx
if i was there i would maybe i can measure one of the hoes the civilains drive around here hahaha:Handshake:
bd928
