Lower Ball Joints Recommendation
Dustin Jackson
Dustin Jackson
@Trey Hardy I wanted to go with Kryptonite balljoints but because of a few factors I’m opting to replace the whole arm. Since the Moog didn’t last long I’m going to try the TTX arms. The Moog bushings seem good still but I can see bits of rubber coming off
Dustin Jackson
Dustin Jackson
Regarding the matte silver finish on the Mevotech TTX parts I guess that’s their anti corrosion process called Repel Tek
DaveO9
Vancouver, WA
Several months/2k miles ago I did all four control arms with Delphis. Quite a bit cheaper than GM, but the castings and all the hardware looked identical. We’ll see how they last. My rig had 200k on it then, just the drivers side upper had a little play.
Charlie207
LFOD, New Hampshire
Where did you order from?
It's about time I do my front upper/lower everything.
AmericanThunder
