5.3 Tick/Knock?
rockola1971
Indiana (formerly IL)
yeah would probably need a right hand drill no chance I fit a normal one in there.
But also I’m starting to think it’s a lifter not an exhaust leak. The tick almost sounds like it’s coming from farther up on that bank not from that exhaust bolt missing.
Drop a quart of transmission fluid in your oil and let idle. See if tick goes away. (Do all this immediately BEFORE you do an oil change). DO NOT drive around with a quart of tranny fluid in your oil. Tranny fluid will free up stuck lifters.
JPVortex
JPVortex
Connecticut
Yeah I’ve read about this will definitely try this when the time comes(still have like 1k miles until the next change). How long would you recommend idling it in the driveway before dropping the oil?
I have added a qt before and driven it like 10 miles, didn't hurt anything and in my case didn't help either but can be worth a try as well
viven44
How likely is it for a loose rocker arm ? If/when valve covers are off, be good to check all the rockers, ensure the engine is at the appropriate TDC positions before checking each rocker.
I don't know much about these LS engines... but assume these are like any old pushrod with non-adjustable valves. I would certainly like a link to any factory manual procedure to check rocker bolt torque for my reference.
Thread below seems like a good reference
According to Haynes, the torque setting for the rocker arm bolts is 22 ft-lbs. And here's the short part of the installation instructions:
viven44
Thanks much. Simple enough. If the OP is trying this, I must insist using an accurate torque wrench. A 3/8 inch torque wrench but I prefer an adapter like this.
JPVortex
JPVortex
Connecticut
Yeah definitely will retighten each of the rocker arm bolts(at least on passenger side) when I do that valve cover gasket job.
Based on the manual that @Fless sent over, seems you don't have to set TDC for each cylinder. Seems like you set cyl. 1 to TDC and tighten half the cylinders bolts down to 22ft lbs. Then you rotate the engine 360 degrees and torque the other side.
Doesn't that mean the whole time you're setting the torque that you'll have cyl. 1 at TDC?
JPVortex
JPVortex
Connecticut
JPVortex
JPVortex
Connecticut
I'm very stupid, obviously it takes 2 rotations to get cyl. 1 to TDC. 360 degrees after TDC would be 180 out from TDC.
Shrubb
