j91z28d1
So for some reason my Bose system is messed up, I only have sound coming from the a-pillar tweeters and the r/f front door panel and the sub in the console. No sound whatsoever on d/s front, 2nd row doors, or d-pillars in the back. Any thoughts from you audio guys? It is a stock non nav head unit. I think it has been like this for a while I am just getting into trying to diagnose. If it is not something simple I will rip out all the factory and go full aftermarket.
I did remove the rear audio control panel in the rear of the console. Don't know if that has something to do with it or not.
@mikez71 @j91z28d1 any thoughts?
I can probably look up the wiring diagram later if @mikez71 doesn't already have it handy. I've not been into mine, so I don't know what does what off the top of my head.
I wouldn't be surprised if the bose amp. gave up, on other cars when you have bose everything runs thru their stuff.
mikez71
Sorry I don't know about the rear panel and the audio,
Could be speakers/amp/headunit...
If the passenger front works, but not the driver... I would focus on driver front first
..since the rears could have something to do with the rear control panel..
ordered new wiper blades these do not last for years but they do not lift even at 130mph (confirmed) and they are cheap a comparable set of bosch is like $50+ at the store
I have thought about switching to the ppv wiper arms but they stick out a lot
j91z28d1
if you pop the end off those with a small flat head you can replace just the rubber. ebay has it, it works well. I get 25in so it covers all my cars and a 6 pack is like 3.99$
I started doing it after I was an hour front home walked in a parts store and it was 50$ for two 25in wipers. like nope, drove home with bad wipers haha.
Charlie207
LFOD, New Hampshire
Some jerkface broke into my car at our Airbnb over the weekend. They stole a few things like a high-end IFAK/first-aid kit and my freaking AutoCAL V3. I had just cut the foam out of an Apache 2800 case to hold the scanner and cables on Thursday, and wanted to bring the scanner with me because I flashed a new update tune Thurday night (basically a v2 of the 50lb injector tune, with some tweaks, and 91+ octane version & TCM tune) and loaded the v1 tune just in case there were any hiccups on our ~400 mile trip up through Maine, and back. (new tune works great, btw).
So, if anyone knows where a cheap, used, AutoCAL V3 can be sourced, and if I can mate the hardware to my tune files, that'd be great*. I emailed BBP about sourcing a replacement, and I'm going to reach out to my insurance to see how hard they laugh about covering the other stuff.
I bet they thought the Apache case was a gun or something.
89Suburban
Bull in the china shop
SE PA
Bastards!!! :mad: :mad: :mad: :mad:
89Suburban
SE PA
@kbuskill thoughts?
swt_wxw
