03 Suburban LT Steering Issues, Wandering and Wobbly and Loose
Another symptom from when my centerlink was oriented incorrectly was inability to keep the thing straight on heavily crowned roads and a feeling of instability at highway speed. With all your parts replaced, make sure the centerlink is installed properly: tie rod droops angled toward the back of the truck so to keep them parallel.
Very easy for the unknowing to put back on wrong.
I keep forgetting about this possible cause. Something to check, posted by @SnowDrifter a while back:
G
GMT800Man90
It's on correct. I fortunately have done work for 16 years and I make sure everything is installed correctly before I finish a job.
G
GMT800Man90
Has the truck ever driven okay? Did you just buy it, or you've had it for a while? Has it ever been in a collision?
I've had it for a few months. It's always had an issue, but the tires that were on it when I bought it were trashed. It's never been wrecked.
G
GMT800Man90
My biggest complaint is this...
The front feels like it's wobbling all over when backing up and when going forward at lower speeds. The wobble is what I have the biggest problem with. The steering wheel has no vibration, smooth as silk. But why the thing wobbles and feels like the tires are skipping the ground while turning is what's really pissing me off
Sounds like it's in 4wd, sometimes called 'crow hopping' -- or the ABS is kicking in due to a faulty wheel speed sensor or the like. Do you feel anything in the brake pedal when it does this?
mattbta
Frisco, TX
you get anything like this happening?
G
GMT800Man90
There's no fault with the abs system. When I got it it did have the typical low speed abs activation where at 10mph you feel it in the brake pedal. But that went away when I did the hubs.
It doesn't feel like it's in 4wd when you're driving. Switch shows 2 Hi. If I push the auto 4wd button and then start to move it hesitates and then Service 4wd comes up. And it won't let me switch back to 2 unless I shut it off and turn it back on. It won't switch into anything else until I do that. If I push the 4hi or 4lo while in 2wd, you can hear it switch and clunk into 4wd. But I haven't needed to use 4wd at all yet.
I know the switches can be faulty a lot. I haven't noticed anything out of the ordinary while under the truck and inspecting the front transfer case or anything. Didn't see any cracks or anything. But usually when you're in 4wd you absolutely feel it while driving. And I don't feel that while driving. I always keep it in 2 hi.
G
GMT800Man90
Could it be bad wheels? I would have thought Firestone would have said something if the wheels were warped or out of round. But it wouldn't surprise me if they didn't even pay attention. It rides smooth as silk though which is where it gets me. Besides the wobble which feels like it's in the wheels. But all suspension parts are tight and new. The only thing I haven't replaced are the original autoride front and rear shocks. Which will be replaced with regular because I could care less about spending stupid money on shocks and a compressor for the autoride.
Bnels82
