Antonm
- Joined
- Apr 2, 2024
- Posts
- 389
- Reaction score
- 397
This is because a 6.2 filled to a 14.7 afr (for example) will make more power than a 5.3 L engine filled up at 14.7 afr.
Is this a statement you are willing to stand behind? Its totally wrong, but that hasn't stopped you before.
If you put 10cc of fuel (or really any given amount of fuel within the range each engine can efficiently burn) in either engine (part throttle stuff where talking here) and mix in air to the same AFR, then guess what,,,,, both engines will be making the same power.
The only slight difference would be any difference in efficiency between the engines (which a 5.3 and 6.2 having the same design, they have pretty similar efficiencies).
So that statement ,yet again, demonstrates a gross conceptual error in your part.
And now you go blathering on about transmission downshifts and other crap. The facts are a 5.3 and 6.2 will get very similar (talking second significant digit differences) in fuel milage if driven under the same conditions, moving the same mass. Even the stupid EPA fuel milage test they put on the window sticker shows this.
