100k differential maintenance question
BlueCollarTahoe
BlueCollarTahoe
thanks for the info guys. appriciate it. does it say on the RPO code what size differential cover this truck has? gonna order some new ones to put on when i change the fluids. want to get the right size.
BlueCollarTahoe
BlueCollarTahoe
Update: did the front diff, the transfer case, and the rear diff with a diff cover switch out. running Mobil1 synthetic in everything. now heres the question for the last part of this 100k maintenance. my transmission fluid is pink. the manual says to do a filter replace and change. ive come to realize this is jsut replacement of what is lost when you change the filter. 5 to 6 quarts. i was gonna go Mobil1 there too but if its not a complete flush and replacement i figured im just adding to whats in there. not sure what was put in there before neither. was thinking of going with :
Castrol 03518 Transmax ATF High Mileage Transmission Fluid
anyone use this stuff? good for this replacement? 04 tahoe AWD.
Yazzy_Fresh_702
