1998 Yukon air conditioning not cold enough
RR1STHD
I have a 1998 Yukon with 225,000 miles and it is all original. The truck has front and rear air. The rear air is 20 + degrees cooler then the front air. Any ideas??
Thx
SunlitComet
OBS Jedi-Do Good
unknown at this time.
:welcome:
The thermal static valve is probably malfunctioning or air is bypassing the evaporator somehow. Have you open the rear end for inspection yet?
R
RR1STHD
No inspection yet, The problem just started this week. Where is the thermal static valve located? Do you know if there is a valve for diverting the air from the heater core to the evap coils?
SunlitComet
OBS Jedi-Do Good
the valve is on the evaporator and looks like this:
Do you have a heat option in rear?(I don't recall the applications) if so there would be a diverter door back there that could not be working properly.
Stresst
How would the expansion valve help the front air?
SunlitComet
OBS Jedi-Do Good
DAMN YOU Stresst, Just have an aneurism and get it over with.:D
Seriously the fronts don't use TSV in the front it uses orifices. And no you can't modify it. with in a few cycles you will blow your high pressure relief valve on the new compressor(keep a camcorder nearby if you decide to try anyway:)).
Stresst
Jonathan, that was not very nice! :shocked:
I want to have an aneurism after receiving my new condenser today, after opening it up I realized they sent the wrong one. This one fits 93-96 suburau impreza:emotions122: This truck officially became the biggest POS I ever owned!:party33:
TigerEyz3
Slow and Steady
TN
+1 on the front orifice being clogged/dirty. Cheap part, easy to replace, but you'll need to evacuate the AC system and run a vacuum to do it right.
SunlitComet
OBS Jedi-Do Good
Why do you keep getting the wrong parts? You went to the same place again?
Stresst
Cause I enjoy effin myself! LMAO The first condenser the shop purchased, this time I ordered the rite one but the sent a differant model! Friggen ridiculous!
You dont know the half of what ive been going through. Never in my life has anything like this happened. AND ITS NOT OVER YET!
traveler613
