2-Channel Dash Cam Install
NoHarmHere
Thanks for this write up, it is much appreciated. One question, where did you connect the ground wire to? I took a quick look in the fuse area and didn’t see anything obvious to connect ground wire to.
Kpwweb
look around the kickspace under the a pillar.
Fast_AT4
RWM +1
SW Florida
With this setup, is the video/live view viewable on the main screen or just recorded to the micro SD?
Morales1995
I have not tried integrating it into the vehicle. This specific dash cam can stream to a phone via. a wifi network that the dash cam puts out.
Do you have any snippets of the quality and such that you would mind sharing? I would greatly appreciate it nice write up by the way!
vwfast
Thanks for this fantastic write up! Installing a 2 channel kit is on my short list of things to do and this will save me a ton of time. Greatly appreciated!
Fast_AT4
RWM +1
SW Florida
Used a bit of info in this thread to do my 2 channel. Thanks OP.
Here are a few pics from my install (didnt feel a need for a new thread).
I would like to note the USB included with the 2 channel setup was "just barely" long enough be be proper for a Yukon XL.
Nice when a project just works out.
lawbet
Thank you, just installed 2ch dashcam. your post really helped.
the annoying cable in the back cannot be tacked in or the back glass won't open. so we have to live with that.
vwfast
Finally got around to installing my Thinkware U1000 and this helped tremendously! Can’t thank you enough for the effort in documenting your install!
Alsherooqi
