2002 yukon xl shock options
ZW7 indicates a variation of the "Premium Smooth Ride" suspension. On the GMT800 chassis the "G65" RPO indicates the Nivomat shocks in the rear (and likely a front shock that is different from the Z71 or standard suspension). The rear springs are also softer. Take both RPO codes into consideration.
M
me262
Codes and shock photos
Those pics do look like the OE Nivomats. You can replace them with like shocks (manual, self adjusting Nivomats - $$) or convert to conventional shocks if you replace the coil springs with standard or Z71 springs.
M
me262
Ok...i loaded the rear axle with over 300 lbs of weight. Took measurements at my hitch before and after. 13" before and 11.75" loaded. Drove it a couple miles and took another measurement. Still 11.75". Drove it another 3 or 4 miles. Measurement wasnow back to unloaded measurement of 13". Maybe nivomats are ok? Maybe my bounce is front shocks? Its worse when i have my camper attached going down bouncy road.
M
me262
I think im going to try kyb shocks on the front. Anyone used these before? Thks!
Yes, I do. Stay away from the Excel-G bottom of the line version. I have Gas-A-Just front shocks for my ZW7 4wd suspension, and they ride the same as OE in mine.
Use the KYB catalog for fitment and part numbers: https://www.kyb.com/catalog/
Stevemo70
