2004 6.0 NV4500 Tahoe
I did not use grease until I lost the one, I was on a roll and had the passenger side done in about an hour and a half. Went to the driver side and decided to start on #7 and that’s when I dropped one. At that point I was starving and getting a little shaky which didn’t help. Taco Bell and using tacky transmission assembly grease kept me in the fight after that.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Tuning is going well so far, initially, I added 20% fuel across the board on the MAF and VE table just to be safe, it was definitely overkill as I saw down to 10.5afr at WOT on the few small pulls I've done. I just figured it would be safer to work on leaning it out than to have it lean and be adding fuel. The great news is I have seen no misfires and there has been zero knock activity! I always had minor KR pop up and random misfires logging all over the place so maybe the mild drop in CR or the cleaning of the pistons I did is helping.
The bad news is I'm pretty sure the front main seal is leaking which isn't a huge deal as I reused the one that's been in it since I bought the truck. If it keeps leaking I can swap it out in an hour or two next oil change.
Good news!:) No more noise on the passenger side?
GMT430guy
