2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
This is getting ridiculous, ac worked great for a week or two then suddenly quit completely. Today I resealed the front cover and tightened all the oil pan bolts which were very loose despite being torqued to spec. Checked AC and it had no pressure at all. Quick look at the line that’s broken 3 times now and yep, same spot it’s leaking out of. WTF!!!!!!
I’m beyond pissed off ac problems are the worst and this is getting to be too much.
... Probably starts sputtering after a half tank when its up on its end like that.
Which sounds really cool through straight pipes. It also gives them a reason to make more frequent fuel station stops so they can cry for your attention with the trap and autotune beeping from the PA horns mounted to their frames.
randeez
south florida
shine a black light under my hood and you see all kinds of leaks :oops:
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I like dat trap shit
But is it AC coolant?
I think I’m gonna weld this line around the base where it’s press fit and give it another shot they are expensive lines.
CoyotesRUS
