2004 With Low Oil Pressure
WildBill
So it had good pressure when you test drove it, then it failed just after?
I had a sending unit go bad in mine, but it read Full pressure (like 80 psi). It was noticeable when I turned the ignition to on, with the engine off, it read 40 psi.
Good luck. I hope they fix it properly.
J
JFranks
Alabama
Just picked up the tahoe from the dealership. The pickup tube had a crack in it. They put a new one in and the pressure is up to 40 at idle. The tech said everythingelse looked good. Best of all "No Charge!"
NJTaho
Central New Jersey
Man thats awesome. Thats good business right there. Happy it worked out for you.
Weley23
