2007 Tahoe 5.3l AFM DOD delete thread
Taheezy_88
Taheezy_88
Sent from my SM-S215DL using Tapatalk
1BADI5
DMV
4wd.
Cam bolt removal? Chilton has no reference to removal. Searching online now
Yeah dropping the pan on a 4wd is not fun, but its a ***** to get that bolt if you don't
I think that cam bolt was a 21mm, i just zipped that out with the impact
Taheezy_88
Taheezy_88
When I went to pop the cam bolt the whole cam and crankshaft rotated so I stopped right there.
edit: ended up using an air impact wrench
kbuskill
NE. FL.
Have you already pulled the heads?
If not, have you already pulled the spark plugs?
If so reinstall the plugs and use the impact.
They make a tool that installs in place of the starter that locks the flywheel in place so it can't rotate. That is how I did mine.
Looks like this...
https://www.ebay.com/itm/143422296740
Okay oil pickup tube bolt. Do I have to drop the oil pan? That's a tight fit any advice?
You can drop the pan and let it rest on the cross member and front axle. This would give you just enough space to use a wrench on the bolt to turn it a flat at a time then finger it out and in. You can snake a new oil pan gasket in there before you bolt the pickup to the new oil pump. DON'T FORGET THE RTV AT THE FOUR POINTS.
Taheezy_88
Taheezy_88
Update*
Got the oil pan dropped enough to pull oil pump. I still need to drop it fully but will get back to that towards the end of the rebuild.
Cam bolt off
Sprocket /timing chain off.
Old camshaft out.
Do I use sealer on any bolt and if so which one?
Torque specs on everything that needs to be torque or a link would be greatly appreciated thx
Cam thrust plate
3 Cam bolts
Valley cover
Harmonic balancer
Head bolts
Exhaust manifold bolts
Intake manifold bolts
Oil pump?
timing cover?
Geotrash
Dave
Richmond, VA
Update*
Cam bolt off
Old camshaft out.
Official I'm in the rebuild stage now.
IMPORTANT KEY INFORMATION ON REBUILD PLEASE let me know
Tomorrow I will install the new cam, cam retention plate, sprocket, chain and oil pump.
I used a Haynes manual. There are torque specs for everything at the beginning of each chapter. Alldatadiy.com also has similar info.
Geotrash
Dave
Richmond, VA
Taheezy_88
Taheezy_88
Thanks! I went ahead and removed the oil pan completely instead today. There is a small line that runs on top of the rack and pinion thats a pain to clear i had to drop the differential to get just enough room.. What a pain in the ass!
Sunday ill start putting everything back together. Still need to send me ecm out
seZ71
