2011 Tahoe no crank no start need help
davidavidd
CO
It appears that the truck is in protected mode, if so this sequence of steps may help you.
what do you need? > cell phone's stopwatch app and a charger to keep your Tahoe's battery alive during the process. Follow the steps in exact order, if you fail in just one, start over.
On page 4 you can identify which system your truck has based on the key, I hope this helps, sorry for my broken English, it's not my native language.
  • pt 77-0011.pdf
R
Rockman101
I have tried this a few times but security light never turns off just stays lit
R
Rockman101
Found this interesting no codes on scanner to reference.
mikez71
Weird that is under starter relay control. I haven't heard of a bad alternator preventing starting before..
When you say you jumped the starter relay, I am assuming you activated the relay and didn't bypass the starter relay?
R
Rockman101
Ya I jumped pin 30 to 87. It also turns over with scanner command mode
R
Rockman101
Does have new ignition and theft module. Something is off though cannot get security light to turn off
ehernande86
