2013 Tahoe Gear Shift Lever loose and will not go into gear.
PatDTN
Just found this on YT
If the doorman doesn't hold then I'm gonna do this... And I'm also in Houston so I feel your pain with the wet heat...
I'm finally back to working on this after being out of town for a couple weeks and then having the Tahoe in the body shop to repair damage from being rear ended. I bought the nylon bushing and it doesn't seem to click on and give any support. After putting an unholy amount of pressure on it to get it in place I can flick it off with my pinky. I'm going for the repair in this video. I've got all the stuff to do a good job of it.
Geotrash
Dave
Richmond, VA
I want that guy's lift.
no need for all that nonsense, the fitting and a drill bit cotter pin and washer works fine, been thru 4 years of abuse still works perfectly fine, will take a whole 5 minutes
and if it needs to come off for whatever reason, pull the cotter pin, done.
PatDTN
I did pull the lever, ground off the rivet and punched it out. Tried to tap it to 1/4-20 but didn't get the tap to bite. I drilled it to accept the same bolt slid through from the back side. My bolt had a lower profile head and the shaft had just a slight flare at the head that let me tap it into place with a hammer. The cable end with the trimmed nylon bushing is just minutely loose. My nut ran down and tightened against the unthreaded shaft just touching the cable. Shifter feels great and I know I won't have to fix it again.
Side note, I injured some fingers on my left hand a few weeks ago and didn't want to fight with putting gloves on. Figured I wouldn't get dirty working on this. I was wrong. Tried out the Fast Orange mechanics' wipes I bought at Walmart and cleaned me right up. Tried it on the door pull that my mechanic* got dirty and cleaned that up too.
*I do all my own work.
SuitedSevens
